Giuseppe Larosa Sun, 05/31/2009 - 03:41
  • Hall of Fame,
    Founding Member
Hello Mohammed,
your C6500 is currently running in Hybrid mode
sup2 with CatOS 7.2(2)
msfc2 with 12.1(8b)E11.
if you want to upgrade to a suitable native mode IOS using feature navigator
www.cisco.com/go/fn
search by platform using 7600 sup2/MSFC2
for example could be
Image Name c6sup22-jsv-mz.121-27b.E4.bin
DRAM / Min Flash 128 / 32
I worry about the ATM module that I don't know if it is supported in native IOS.
By the way, is it still used and for what ?
the procedure for conversion for sup2/msfc2 is here
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml
otherwise you can upgrade catOS up to 8.3.4 and the msfc to
Image Name c6msfc2-jsv-mz.121-27b.E4.bin
DRAM / Min Flash 128 / 16
notice the different naming convention between native and hybrid (sup22 vs. msfc2)
Hope to help
Giuseppe
mohammedrafiq Tue, 06/02/2009 - 04:58
Thanks Giuseppe,
ATM cards are not in use any more.
as you said
"search by platform using 7600 sup2/MSFC2"
Is this will be compatible with 6509.
Regards.
Giuseppe Larosa Tue, 06/02/2009 - 05:07
  • Hall of Fame,
    Founding Member
Hello Mohammed,
if ATM linecards are not a concern you can move to Native IOS following the procedure I have linked in my first post.
If you look at the ios image name for C7600 sup2/msfc2 native ios it is :
Now, with more modern HW and IOS images C7600 is separated from C6500 but with sup2/MSFC2 they are the same.
At the beginning moving from Hybrid mode to Native IOS made a C6500 to become a C7600.
You should be fine with it
Hope to help
Giuseppe
