htluo Thu, 05/28/2009 - 08:03
  • Red, 2250 points or more
Standard power won't work.
You may use the command "show environment". If you see "AUX power", that's good for PoE.
Or you can look at the chassis. If you see something like, 2811-AC-IP, it should support PoE.
Michael
http://htluo.blogspot.com
shamkumar Mon, 06/07/2010 - 12:03
sh environment
Main Power Supply is AC
Fan 1 OK
Fan 2 OK
Fan 3 OK
Fan Speed : Normal
System Temperature: 27 Celsius (normal)
Environmental information last updated 00:00:24 ago
Its not showing AUX power that means POE wont work....ok if POE doest work no problem i have alternate.....my q? is can i use this 4ports for switching if yes can any one guide me how to use them.....coz i tried but didnt worked..........thanks in advance.....
