How can i verify the Serial number of GBIC
May 28th, 2009
Hi All,
May i know the command to verify the serial number of GBIC?
Thank you,
Overall Rating: 5 (1 ratings)
glen.grant Thu, 05/28/2009 - 06:59
"show idprom interface gx/x " should give you that . This is on newer switches like 4500's and 6500's ,3650's etc...
sivaprakasam81 Thu, 05/28/2009 - 07:14
I use 3548-xl-en Switch. The show idprom is not listed? Can you please give me right command to check in the 3548 Switch.
Giuseppe Larosa Thu, 05/28/2009 - 07:00
Hello Sivaprakasam,
your switch may support
sh inventory
this tells the s/n
Hope to help
Collin Clark Thu, 05/28/2009 - 07:03
I have never been able to find the command for stackables, but for chassis switches try-
show idprom interface gigabitEthernet [port number]
Hope that helps.
Leo Laohoo Thu, 05/28/2009 - 14:45
The WS-C3500-XL-EN does not have the support to "interrogate" the GBIC for details such as S/N. You have no choice but to pull it out.
