ACS CPE Framed IPv6 Address
May 28th, 2009
I am trying to test IPv6 with ADSL Services, in which the Client CPE is assigned an IPv6 Address. Can anyboy let me know what I need to enter into the user account on ACS so that the CPE is assigned a Framed IPv6 WAN Address. I will manually assign the CPE LAN IPv6 Allocation.
Thanks in advance.
D.
bwilmoth Wed, 06/03/2009 - 13:34
  • Silver, 250 points or more
CiscoWorks Common Services enables you to define which roles are assigned to each user. By changing the role definition for a user, you change the types of operations this user is authorized perform in Security Manager. For example, if you assign the Help Desk role, the user is limited to view operations and cannot modify any data. However, if you assign the Network Operator role, the user is also able to modify the configuration archive. You can assign multiple roles to each user.
