L2L Site VPN issue
May 28th, 2009
I have had a site that has worked with no problem until today. I am getting Phase 1 with no problem and have multiple IPSEC tunnels established. The problem I am having is with the remote site getting to a specific host. I am getting the following from my debugs. Any help is appreciated.
May 28 11:24:10 [IKEv1]: Group = X.X.X.X, IP = X.X.X.X, QM FSM error (P2 struct &0xd0b129b8, mess id 0x31fe72e1)!
May 28 11:24:10 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, IKE QM Initiator FSM error history (struct &0xd0b129b8) <state>, <event>: QM_DONE, EV_ERROR-->QM_WAIT_MSG2, EV_TIMEOUT-->QM_WAIT_MSG2, NullEvent-->QM_SND_MSG1, EV_SND_MSG-->QM_SND_MSG1, EV_START_TMR-->QM_SND_MSG1, EV_RESEND_MSG-->QM_WAIT_MSG2, EV_TIMEOUT-->QM_WAIT_MSG2, NullEvent
May 28 11:24:10 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, sending delete/delete with reason message
May 28 11:24:10 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, constructing blank hash payload
May 28 11:24:10 [IKEv1]: Group = X.X.X.X, IP = X.X.X.X, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
May 28 11:24:10 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, IKE Deleting SA: Remote Proxy Z.Z.Z.0, Local Proxy Y.Y.Y.Y
May 28 11:24:10 [IKEv1]: Group = X.X.X.X, IP = X.X.X.X, Removing peer from correlator table failed, no match!
May 28 11:24:10 [IKEv1 DEBUG]: Pitcher: received key delete msg, spi 0xb82af5cc
May 28 11:24:14 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
May 28 11:24:14 [IKEv1]: Group = X.X.X.X, IP = X.X.X.X, IKE Initiator: New Phase 2, Intf inside, IKE Peer X.X.X.X local Proxy Address Y.Y.Y.Y, remote Proxy Address Z.Z.Z.0, Crypto map (fleet-map)
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, Oakley begin quick mode
May 28 11:24:14 [IKEv1 DECODE]: Group = X.X.X.X, IP = X.X.X.X, IKE Initiator starting QM: msg id = f0349ecc
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, IKE got SPI from key engine: SPI = 0xcd4c329f
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, oakley constucting quick mode
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, constructing blank hash payload
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, constructing IPSec SA payload
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, constructing IPSec nonce payload
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, constructing proxy ID
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, Transmitting Proxy Id:
Local host: Y.Y.Y.Y Protocol 0 Port 0
Remote subnet: Z.Z.Z.0 Mask 255.255.255.0 Protocol 0 Port 0
May 28 11:24:14 [IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, constructing qm hash payload
May 28 11:24:14 [IKEv1 DECODE]: Group = X.X.X.X, IP = X.X.X.X, IKE Initiator sending 1st QM pkt: msg id = f0349ecc
May 28 11:24:14 [IKEv1]: IP = X.X.X.X, IKE_DECODE SENDING Message (msgid=f0349ecc) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NONE (0) total length : 160
r-garrison Fri, 05/29/2009 - 14:03
Sounds a bit like your encryption domains (the ACLs attached to the crypto map) don't quite mirror each other. Is there a difference? Could be a subnet mask mistype or any number of small clerical errors.
