Warning message
How to verify the software images presence and version?
May 28th, 2009
Hi All,
I use 26xx router. How can i verify the following software image presence and version,
1. Cisco Unified Callmanager Express software
2. Cisco Unity Express Software
Thank you
Overall Rating: 5 (1 ratings)
Kenneth Mohammed Thu, 05/28/2009 - 09:15
  • Silver, 250 points or more
You can find the info you need by telnetting to the router, and issuing the command "show telephony-service". This will show you the CME version. To get the CUE version, telnet to the AIM or NM by issuing the command "service-module Service-Engine x/x session", once you are in, issue the command "show software version".
Or you could simply access the GUI and the info will be under Help--->About.
Hope that helped, if so please rate.
sivaprakasam81 Thu, 05/28/2009 - 09:24
Can you please provide me the link to get more information on Telnet and GUI lookup for software version?
Thank you,
