Warning message
How to verify the following in 7960 IP Phone?
May 28th, 2009
Hi All,
How do I verify the following in 7960 IP Phone,
1. IP address of the phone
2. CME software version
3. Extension number
And how to access the GUI prompt of Cisco 7960 IP phone?
Thank you,
Overall Rating: 5 (2 ratings)
Jaime Valencia Thu, 05/28/2009 - 10:45
  • Cisco Employee,
  • Hall of Fame,
    2011
you can use show commands:
Commands: show ss7 sm set through shutdown (voice-port)
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_sh4_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1011792
Cisco Unified CME Commands: sast1 trustpoint through show fb-its-log
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html
The whole config guide
Cisco Unified Communications Manager Express System Administrator Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
To access phone GUI just type the IP of the phone in a browser
java
if this helps, please rate
david-lima Thu, 05/28/2009 - 10:54
  • Bronze, 100 points or more
Hi friend.
1. Settings->Network Configuration to check IP, Mask, Gateway, TFTP.
2. You can check only the firmware.
3. If the phone is configured, you can check directory number on the display of the phone.
To web access: http://IPPhone-IP
All the best
David
