boot: cannot load "flash:"
When trying to restore the settings for a brandnew Router 881, something went wrong. I can't access the router anymore on a normal way.
Using terminal i get:
Upgrade ROMMON initialized
loadprog: bad file magic number: 0x0
System Bootstrap, Version 12.4(15r)XZ5, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower memory rommon use
C880 platform with 262144 Kbytes of main memory
rommon 1 >
I can't "flash" a file, because I don't have one. It is not on the CD.
And when I look in the support site I can see it, but I can't download it. Apparently I have to pay for it. Is this correct ?
Also I can not get any support from Cisco by the phone. First I have to pay for a support contract.
Is this the way Cisco works ? Pay for every kind of support, download, ... ?
Paolo Bevilacqua Thu, 05/28/2009 - 12:03
  • Hall of Fame,
    Founding Member
If your router is brand new, you're covered by the initial warranty. This must be given to you by the reseller, and if they refuse to, by cisco TAC, they may ask for a copy for your invoice perhaps.
Paolo Bevilacqua Thu, 05/28/2009 - 15:38
  • Hall of Fame,
    Founding Member
You have assigned a cisco rep called CAM or so. Contact him/her and let know of the issue and ask to escalate. At same time talk to TAC, remember then warranty by law and ask for a case be opened with serial number. Basically, you should always entitled to support with a new item. Else,it's your right to return the item.
Leo Laohoo Thu, 05/28/2009 - 16:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
No it's not. It's called "buck-passing" at it's best. The distributor needs to have a course in CUSTOMER MANAGEMENT.
I hope you have the name of the distributor who fobbed you off so you can give this to the CAM.
... And look for another distributor. They don't need your business.
