May 28th, 2009
Any one know what "Spoofed packets dropped" and the "Packet pullups needed" are? Is the WAAS dropping packets it thinks it's being spoofed? Also, how can I get rid of the pullups? The WCCP setup is as follows; l2 forward/return to a 3750E stack switch, interfaces are setup as standby and the model is a 7371. I'm not using any WCCP redirect list.
Transparent GRE packets received: 0
Transparent non-GRE packets received: 1940435323
Transparent non-GRE non-WCCP packets received: 0
Total packets accepted: 461319375
Invalid packets received: 731
Packets received with invalid service: 0
Packets received on a disabled service: 0
Packets received too small: 0
Packets dropped due to zero TTL: 0
Packets dropped due to bad buckets: 617
Packets dropped due to no redirect address: 0
Packets dropped due to loopback redirect: 227
Pass-through pkts dropped on assignment update:61
Connections bypassed due to load: 0
Packets sent back to router: 1829
GRE packets sent to router (not bypass): 0
Packets sent to another WAE: 63037
GRE fragments redirected: 1116193
GRE encapsulated fragments received: 0
Packets failed encapsulated reassembly: 0
Packets failed GRE encapsulation: 0
Packets dropped due to invalid fwd method: 0
Packets dropped due to insufficient memory: 0
Packets bypassed, no conn at all: 0
Packets bypassed, no pending connection: 0
Packets due to clean wccp shutdown: 0
Packets bypassed due to bypass-list lookup: 166
Packets received with client IP addresses: 460833489
Spoofed packets dropped: 57416
Conditionally Accepted connections: 0
Conditionally Bypassed connections: 0
L2 Bypass packets destined for loopback: 0
Packets w/WCCP GRE received too small: 0
Packets dropped due to received on loopback: 219
Packets dropped due to IP access-list deny: 0
Packets fragmented for bypass: 0
Packets fragmented for egress: 0
Packet pullups needed: 5484
Packets dropped due to no route found: 0
