Multiple WLC LobbyAdmins
May 28th, 2009
My understanding is that I can authorise multiple Lobby Admins on a WLC 4404 using RADIUS. I was wondering is if is possible to create Lobby Admin groups so that a specific Lobby Admin can only grant guest wireless access to specific Mobility Groups?
I support wireless in multiple facilities and handing off guest access admin duties to department secretaries is ideal, but I only want guests to have wireless access only from the area/building in which they will be visiting.
Is this possible using a single WiSM (70+ WAPs) or do I need to deploy multiple WLCs?
Thank you in advance for your help.
Leo Laohoo Thu, 05/28/2009 - 14:58
"I only want guests to have wireless access only from the area/building in which they will be visiting."
I can think of two ways of doing this ...
1. Create AP Groups. This method allows you to broadcast a specific SSID in a specific area.
2. Each Lobby Administrator can only see the account created. Lobby Admin 1 can't/won't be able to see accounts created by Lobby Admin 2, for instance.
Hope this helps.
3. Lobby Admins must be strict. Do not allow them to create 31-days account (no time limit).
Trending Topics - Security & Network
