ATM/T1 Point to Point circuit
May 28th, 2009
I'm trying to troubleshoot a bandwidth. I have several point to point T1's in my district that all map back to a single location. The ping times from one particular 2651 router to a host machine at the remote site are very high. There are only about 10 users at the remote site who access an SQL application. It is a 1.5MB point to point via ATM to an LS1010. Any ideas of where to begin to pinpoint the latency?
Overall Rating: 3 (2 ratings)
paolo bevilacqua Thu, 05/28/2009 - 20:50
  • Hall of Fame,
    Founding Member
What's the delay difference? Do you see any error on interfaces?
Sean McCoy Fri, 05/29/2009 - 05:00
The ping times are very erratic. When issuing a PING command to a host on the other end of the WAN link, it varies from 4/7/8 ms to 4/20/36 ms. I'm just trying to pinpoint. What troubleshooting methods can I use to determine errors on either the LAN or WAN interface?
pompeychimes Fri, 05/29/2009 - 06:22
  • Bronze, 100 points or more
Are ping times between WAN interfaces consistent? If yes the problem is likely in either LAN. If no the problem is likely on the circuit. Apart from eratic ping times are you experiencing any other issues.
Sean McCoy Fri, 05/29/2009 - 06:54
Ping times are not consistent. From the remote router (WAN interface IP 192.168.1.22), a ping to to the other side (192.168.1.21) reveals 4/6/8 ms then another ping command comes back 32/36/48 ms. It seems to bounce around quite a bit. I've had the ISP test the circuit which always comes back clean. I would like to get them onsite to check the TELCO equipment but I doubt they will come out.
pompeychimes Fri, 05/29/2009 - 07:01
What does the cpu, mem, and circuit utilization look like? Ping inconsitentcy aside what is the actual problem you are troubleshooting?
Sean McCoy Fri, 05/29/2009 - 07:05
I have an SQL database that the remote sites accesses for student records. There is latency when they open the application at the remote side. I would point the finger at bandwidth as the culprit but there are only 10-12 users at the remote site. What are the commands to check out memory, cpu and circuit utilization?
pompeychimes Fri, 05/29/2009 - 07:12
sh mem stat
sh proc cpu
sh int (Int name and number)
post output here if you need assitance.
Sean McCoy Fri, 05/29/2009 - 07:29
sh proc cpu and sh mem stat too large to post here
jimmysands73_2 Fri, 05/29/2009 - 12:08
  • Silver, 250 points or more
"sh proc cpu and sh mem stat too large to post here"
You can also cut/paste it into a .txt file, and add it here as an attachment.
Sean McCoy Fri, 05/29/2009 - 07:31
Sho int command from other side of WAN link:
OB_BOE_Admin7206VXR_WAN#sho int ATM2/0.60
ATM2/0.60 is up, line protocol is up
Hardware is ENHANCED ATM PA
Description: 1.5MB ATM Conn. to John Glenn School remote CID ASST.100136..NW
Internet address is 192.168.1.21/30
MTU 4470 bytes, BW 1500 Kbit, DLY 190 usec,
reliability 255/255, txload 26/255, rxload 5/255
Encapsulation ATM
183295589 packets input, 4017060384 cells, 188578314481 bytes
154333010 packets output, 1452881578 cells, 67840699668 bytes
0 OAM cells input, 0 OAM cells output
AAL5 CRC errors : 154
AAL5 SAR Timeouts : 0
AAL5 Oversized SDUs : 0
paolo bevilacqua Fri, 05/29/2009 - 14:37
  • Hall of Fame,
    Founding Member
Hi, sometime few users are more than enough to saturate a circuit. Are you taking bandwidth usage graphs ?
Sean McCoy Fri, 05/29/2009 - 07:27
sho int command:
OBBOE_JohnGlennSchool_2651#sho int ATM1/0.10
ATM1/0.10 is up, line protocol is up
Hardware is ATM T1
Description: 1.5MB ATM PVC to AdminBldg Remote CID 24.ASST100130..NW
Internet address is 192.168.1.22/30
MTU 4470 bytes, BW 1500 Kbit, DLY 20000 usec,
reliability 255/255, txload 69/255, rxload 69/255
Encapsulation ATM
95735450 packets input, 44942234040 bytes
113557778 packets output,116857343068 bytes
AAL5 CRC errors : 12
AAL5 length violation : 0
AAL5 CPI Error : 0
pompeychimes Fri, 05/29/2009 - 10:06
At the time you issued thes commands all looks well as far as load on the circuit is concerned. For troubleshooting purposes i'd recomend changing the load interval to 30 secs on both sides to get a more accurate picture.
Are only remote site users having trouble with the app?
Did the app ever work / respond efficently?
Is the problem consistently a problem or every now and again or at certain times during the day?
What other types of traffic traverse this link?
Is there any QoS configured?
Joseph W. Doherty Sat, 05/30/2009 - 04:19
I've found variable latency is often, altough not always, caused by transient congestion when using FIFO queuing.
Consider a single large packet of 1500 bytes, or 12,000 bits, will take (12,000/1.5 Mbps) = 8 ms to serialize (it would be somewhat more for ATM due to "cell tax"). So, it doesn't take many large packets, in a FIFO queue, to provide varible latency. (I'll come back to this shortly.)
Since ATM is a cloud technology, it's possible there's transient congestion caused by other (not yours) traffic within the ATM cloud. If you're within your contracted PVC bandwidths, you can complain to your provider. However, even if you're not within contract, it's unusual to encounter this with many ATM providers, especially within the US and at T1 PVC bandwidths. More often we need to worry about the T1 bottleneck at our site, both ingress and egress.
So, back to our sites, for T1 bandwidths, it doesn't take many large packets in a FIFO queue to contribute to variable latency.
Some transient congestion can be hard to "see" with ordinary monitoring which sees an average load over some "large" time period (half minute or minutes) vs. millisecond time periods (as seen by pings).
Even with high precision bandwidth monitoring, under certain conditions of congestion, overall average utilization can still be low. This can happen for TCP if it keeps getting driven into slow start or has transmission timeouts. (This can be recognized if you have stats on interface drops - including ATM cloud egress.)
Even if the congestion/load isn't high enough to cause drops, again, it's possible there are microbursts that queue. If you can capture stats for current queue lengths (software and hardware [there's also the interface FIFO queue]), you can sometimes "see" this (also again, there's ATM cloud egress to consider).
Given the above background, one method to confirm transient congestion, besides monitoring queue depths (difficult to impossible on ATM cloud side), would be to implement policers with a minimum Tc, to "clock" bandwidth usage. The policer would pass all traffic, but it's stats might show the bursts.
If you don't want to take the time to confirm whether micro bursts are the issue, you can just implement QoS techniques to generally deal with them. For instance, on the branch site set hardware interface queue to minimum (tx-ring-limit 2 or 3) and FQ at the software level. At the hub/HQ, if it has a larger physical bandwidth to the ATM cloud, insure it doesn't overrun branch bandwidth, it too uses FQs (per PVC) and minimize its hardware FIFO.
Done correctly, pings latencies (if the prior is the issue), should be much more consistent regardless of overall link loading. Users should also see more consistent performance, although they will still see performance decrease if the link is loaded (less bandwidth per user).
PS:
BTW, as to number of users, just one can often easily max a T1 that has little latency. Something as simple as openning a large file, e.g. Powerpoint, across a T1 can degrade other users while the data is transfered with FIFO.
Assuming all users are just using SQL, and it's a server variant, this is less likely although large results sets can cause an issue too.
paolo bevilacqua Sat, 05/30/2009 - 09:46
  • Hall of Fame,
    Founding Member
To the person that rated "1" the post above:
Go have a conversation with yourself on behaving in professional venues, and do not come back on this forum unless you can obey rules of fairness and respect.
My rating, a "5".
