Outbound Calling not going using FXO
May 28th, 2009
We have VIC2-4FXO & EVM-HD (8FXS/DID) card installed into our Voice Gateway (2821)..VG & CCM (7.0) is integrated properly..
FXO ports are configured as Ground Start & in the Attendant DN we have given one of the extension numbers...
The problem is: whenever we want to dial outbould calls over FXO we get a fast busy tone, where as from Outside we can dial that FXO line & there is no issue with voice clarity..
All the FXO lines are showing OFFHOOK in idle scenario....
Attached output for command " debug voice ccapi inout".
Dennis Mink Thu, 05/28/2009 - 19:51
  • Blue, 1500 points or more
your attachment is not included in this post ;-(
if you shut/no shut your fxo ports, do the go into on-hook?
also, are your dial-peer pointing to the FXO ports for outbound calls?
acharyr123 Fri, 05/29/2009 - 01:53
Thanks for your reply...Plz find the attachment...
Yes,if i do shut/no shut for the FXO ports, the status gets changed to on-hook...Plz find the gateway config as well..
paolo bevilacqua Fri, 05/29/2009 - 04:26
  • Hall of Fame,
    Founding Member
Which exact IOS is this ?
acharyr123 Fri, 05/29/2009 - 06:29
Platform: 2821( C2800NM-SPSERVICESK9-M, Version 12.4(20)T2
