Switch Compatability for IP phone 7960
May 28th, 2009
Hi All,
We will be using 7960 IP phone(15 Nos). Do I need PoE supported Switch/router or can I use any Switch?
Can you please name the supporting Hardware requirements for the same.
What are all the important Interface modules do i need?
Thank you,
Overall Rating: 5 (1 ratings)
Rob Huffman Thu, 05/28/2009 - 12:07
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Siva,
With the 7940/7960 series you will require a switch that supports Cisco Pre-Standard PoE. So another provider like Linksys will not work (all Cisco PoE switches are backwards compatable for Pre-standard I believe). The phones can also be powered locally but this is a very messy solution. Have a read of this good Cisco doc;
Power over Ethernet (PoE) Power Requirements FAQ
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00808996f3.shtml
Hope this helps and best of luck!
Rob
