How to find out where message is coming from and stop it
Answered Question
May 28th, 2009
Hey folks, on my recently configured c2950-i6q4l2-mz.121-22.ea4a.bin I keep getting the message below. Is there any IOS command to let me pinpoint from which process and reason this message is coming from?
sw#
*Feb 28 16:35:12.031: %IP_SNMP-3-SOCKET: can't open UDP socket
*Feb 28 16:35:12: Unable to open socket on port 161
*Feb 28 16:36:12.031: %IP_SNMP-3-SOCKET: can't open UDP socket
*Feb 28 16:36:12: Unable to open socket on port 161
Correct Answer by Jon Marshall about 8 years 4 weeks ago
Marlon
Can you type "no snmp-server" from global config.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 05/28/2009 - 12:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marlon
Check your SNMP config on the switch or alternatively post the config.
Jon
Giuseppe Larosa Thu, 05/28/2009 - 12:13
  • Hall of Fame,
    Founding Member
Hello Marlon,
have you configured SNMP on this device ?
you can check with
sh snmp
sh run | inc snmp
UDP port 161 is SNMP, UDP port 162 is for SNMP traps
if SNMP is configured the message is telling that the switch is not able to allocate an UDP socket to answer to an SNMP get that comes from a network management system.
check free memory with
sh proc mem | inc Free
Hope to help
Giuseppe
news2010a Thu, 05/28/2009 - 12:40
This is the strange part:
If i do 'sh run | inc snmp' the only command related to snmp is:
sw#show run | in snmp
snmp-server engineID local 900000070200001CC1C02C50
Then I do
config t 'no snmp-server engineID'
the 'cant open UDP socket' message persists.
Then I do again 'show run | in snmp' and such entry remains in the configuration.
Any ideas on how to get rid of this?
Correct Answer
Jon Marshall Thu, 05/28/2009 - 12:48
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Marlon
Jon
news2010a Thu, 05/28/2009 - 12:52
The 'no snmp-server' did it.
Well, I can't quite understand why by typing the entire string the command was not removed though.
Thank you very much folks.
Jon Marshall Thu, 05/28/2009 - 13:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No problem Marlon, glad to have helped.
Jon
