Ip inspect tcp reassembly
Endorsed Question
May 28th, 2009
Hi guys!
here is my problem, i had a 2821 ISR ADV security, when i try to download a file from the web bigger than 10 mb, repently the router close the conection.
with the message the server reload the conection.
i hope you can help me! Regards!
Endorsed by Julio Carvajal
clopezj07 about 7 years 7 months ago
yes the firewall is working & is from all web servers,Actually i resolved the problem, modifin' with this values..
ip inspect tcp finwait-time 10
ip inspect tcp max-incomplete host 1000 block-time 0
ip inspect tcp reassembly queue length 1024
ip inspect tcp reassembly timeout 60
ip inspect tcp reassembly memory limit 256000
now the problem is solved!
thanks!
Overall Rating: 5 (1 ratings)
ROBERTO TACCON Sat, 05/30/2009 - 11:07
If you download others bigger files from other servers the problem is still present ?
Is the router configured with IOS firewall ?
Which is the runnig conf ?
clopezj07 Mon, 06/01/2009 - 10:28
thanks!
