05-28-2009 05:45 PM - edited 03-14-2019 04:09 AM
Anyone experienced no ringback when using this TCL and in SRST, and if so did you find a way to fix it?
Chad
Solved! Go to Solution.
05-30-2009 05:03 PM
Chad,
I believe the survivability script invokes the pleasewait.wav and holdmusic.wav when its used. Do you have these in flash? I suppose you could replace them with ringback.wav file if you wanted.
Chris
05-30-2009 11:01 AM
confirmed on 2 sites now, no ringback. Does this work for anyone?
Chad
05-30-2009 05:03 PM
Chad,
Chris
05-30-2009 10:33 PM
Chris,
I def don't but I can upload them. Thanks a ton dude, I knew it was a TCL something or other :)
Chad
