Call Forward Issue
Using CUCM 7.0.5, I have a T1-PRI integration to a Nortel M1 Option 51c through DMS-100. The single PSTN PRI is connected to 51c. If I set CallForwardAll on a Cisco phone to a local PSTN number, when a Nortel phone calls to that Cisco phone, it got an error of "Cause i = 0x81E3 - Information element not implemented" on cisco router. If I CFA to a long distance number, the call goes thru successfully. I unchecked "display IE" and changed numbering plan to "National" and "ISDN", it did not help.
Paolo Bevilacqua Thu, 05/28/2009 - 20:23
  • Hall of Fame,
    Founding Member
Are you using H.323 or MGCP ?
Can you include the entire trace ?
MGCP - the following is the failed local CFA
*May 28 23:13:03.308: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE980830A
Exclusive, Interface 0, Channel 10
Display i = 0xB1, 'Ricky Lai'
Calling Party Number i = 0x0980, '7612'
Plan:Private, Type:Unknown
Called Party Number i = 0x89, '7505'
*May 28 23:13:03.336: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8A
*May 28 23:13:03.340: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x000B
Standard = CCITT
Channel ID i = 0xE9808301
Display i = 'Sonia Dutta'
Calling Party Number i = 0x0083, '7612'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '96041234567'
Original Called Number i = 0x00000F81, '7505'
Redirecting Number i = 0x00008F, '7505'
*May 28 23:13:03.392: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8B
*May 28 23:13:07.384: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8B
Progress Ind i = 0x8180 - Reserved value
*May 28 23:13:07.388: ISDN Se0/0/0:23 Q931: TX -> PROGRESS pd = 8 callref = 0x8A
*May 28 23:13:07.408: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0A
Cause i = 0x81E4 - Invalid information element contents
*May 28 23:13:07.428: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8A
*May 28 23:13:07.436: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x000B
*May 28 23:13:07.480: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8B
*May 28 23:13:07.496: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x000B
This is the successful Long Distance CFA:
Standard = CCITT
Display i = 0xB1, 'Sonia Dutta'
Standard = CCITT
Called Party Number i = 0x80, '96047109996'
