Dot1Q Tunneling
May 28th, 2009
Hi, I have tree switch-
Sw1 (F0/1) is connected with Sw2(F0/1)
SW3 (F0/15)is connected with Sw2(F0/15).
SW1 is in Domain -A Server mode. Sw2 is in Transparte mode. SW3 is in Domain-A,client mode.
I want all vlans created on SW1 should propagete to SW3. But the barrier is SW2. SHould I congifure Dot1Q-Q Tunneling on F0/1 & F0/15 of SW2 ? Any tunnelling configuration needs on SW1 or SW3 ?
Giuseppe Larosa Thu, 05/28/2009 - 22:13
Hello Rupesh,
you just need standard trunk links.
Verify that the VTP transparent switch is running vtp version 2
With VTPv1 a transparent switch verifies the vtp domain if different it discards VTP messages.
sh vtp status
for the check
Hope to help
sonyscaria Thu, 05/28/2009 - 22:52
so if all are in VTP V2, the transparent switch domain should'nt match with client/ server.?
Giuseppe Larosa Fri, 05/29/2009 - 02:52
Hello SonyS,
yes the vtp domain on the vtp transparent switch can be different if VTP version 2 is running on the transparent switch.
Hope to help
