ASA VPN error
May 28th, 2009
Getting VPN Error while connecting VPN session,Pls find attachments.It is happening Intermittently.No change in configuration and Error is generating to all profiles.
Any Sort of Help would be appreciated.
Tnks
Ramu
ajaylandge Fri, 05/29/2009 - 02:23
You probably have VPN concentrator as a VPN server, please enable NAT Traversal (NAT-T) or IPsec over User Datagram Protocol (UDP) on it.
Please refer TAC case # K71102938 for details.
Ajay
ajaylandge Fri, 05/29/2009 - 02:36
Sorry I didn't see the subject line, it's ASA, but doesn't matter, you can add following command in global configuration mode:
crypto isakmp nat-traversal
Ajay
RamuChichula Fri, 05/29/2009 - 06:25
What is the meaning of the command,What will happen? this is for my knowledge only.
Above the VPN Firewall we have a Cisco Router, have allowed all traffic (TCP+udp=IP) to that VPN Public Ip Interface from Outside in the Router.Pls clarify me regarding this,Is any thing to do in the Router.
I Given udp any any in Router outside interface.Eventhough Problem coming Intermittently.
Tnks
Ramu
