wism startup wizard
May 29th, 2009
I am trying to get into startup wizard.basically i issue reset system followed by recover-config at username prompt but wism prompts me for the password.
This was mentioned in the Cisco WLC configuration guide.
Any help is much appreciated.
cheers,
Janesha
(WiSM-slot1-1) >reset system
The system has unsaved changes.
Would you like to save them now? (y/N) y
Configuration Saved!
System will now restart!
02:53:21: %WiSM-5-STATE: Controller 1 in slot 1 is Oper-Up
[Connection to 10.0.1.67 closed by foreign host]
wireless7#10.0.1.67
Trying 10.0.1.67 ... Open
(WiSM-slot1-1)
User: recover-config
Password:
weterry Fri, 05/29/2009 - 05:04
I believe you can only do this consoled in to the wism directly with the serial connection.
George Stefanick Fri, 05/29/2009 - 09:35
Q. How can I reset the WiSM to factory default settings?
A. Complete these steps to reset the WiSM controller to factory defaults:
1. Enter reset system at the WiSM controller CLI.
2. At the prompt that asks whether you need to save changes to the configuration, enter Y or N. The unit reboots.
3. When you are prompted for a username, enter recover-config to restore the factory default configuration. The Cisco WLAN controller reboots and displays this message:
Welcome to the Cisco WLAN Solution Wizard
Configuration Tool
4. The WiSM is now reset to factory defaults. Use the configuration wizard to enter new configuration settings.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_qanda_item09186a00806e39b7.shtml#Q7
If you find this post helpful please rate it
janesh_abey Fri, 05/29/2009 - 13:00
Hi George,
This is exactly the what I followed as mentioned in the config guide 5.2. However, it didn't work.As Terry suggested, I will try to reset the config by directly connecting to wism.
cheers,
Janesha
