CUCM 5.1 3 selecting audio port range IP comminicator
Answered Question
May 29th, 2009
We are implementing IP Communicator for agents over the wan and wish to restrict the RTP audio. Below is a Cisco link that informs it can be done in CallManager as well as the communicator. However, I cannot find this option in the CUCM, Can anyone help
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/2_0/english/administration/guide/CADcfg.html#wpxref74880
Simon
Correct Answer by Rob Huffman about 7 years 12 months ago
Hi Simon,
When you configure IP Communicator in CUCM have a look at the Phone Configuration page, down towards the bottom. You will see;
Product Specific Configuration
and then these two options;
RTP Port Range Start
RTP Port Range End
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 05/29/2009 - 04:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Simon,
RTP Port Range End
Hope this helps!
Rob
Rob Huffman Mon, 06/01/2009 - 04:23
  • Hall of Fame,
    Founding Member
Hi Simon,
You are most welcome my friend :)
Cheers!
Rob
nickpalmermorewood Mon, 08/17/2009 - 23:23
Is there any way of reducing the RTP port range globally on the CM, as opposed to just on the softphone phone configuration.
So that one could force a standard phone like a 7940 to only use a specific port range.
