UT not discovering MAC on trunk port with IP-phone
May 29th, 2009
I have a Lan with interfaces configured for non-cisco-ip-phone. (i.e.: Trunk port with a native data vlan.)
It is impossible de discover Mac on those ports. Note that if I telnet the switch and do a 'sh mac add-table" I see those.
I configured the LMS User-Tracking admin with:
"config trunk for end host disc. = enable on all trunk."
Do I forgot something ?
Rgds,
Michel Misonne
Joe Clarke Fri, 05/29/2009 - 07:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Edit ut.properties, and set UTGetVlansWithUserPorts=0. Then run a new UT acquisition, and your phones should show up.
mmisonne Mon, 06/01/2009 - 04:41
I tried to do this allreaddy.
And I did not see any change.
Here is my ut.properties.
Note that I have LMS3.1
Rgds.
Michel.
Joe Clarke Mon, 06/01/2009 - 08:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try running a full Campus Data Collection first, then run the UT acquisition.
mmisonne Wed, 06/03/2009 - 09:31
hi Jim,
I am sorry to call you back , but I need to do this working.
Do I need to do other thing than edit UT.properties ?
Do I need to restart LMS ?
Do I need to schedule a new inventory pooling ?
Joe Clarke Wed, 06/03/2009 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
All you should have to do is run a new Campus Manager Data Collection. This will update the XML files which contain port data required by User Tracking. After the Data Collection runs, start a new UT acquisition. Your end hosts should show up.
