High CPU Utilization in cisco switch 2900XL-Urgent
We have few switches of 2900XL series in production.CPU utilization is above 90% in 2-3 switches which is causing a very slow network traffic and high round trip time.From "sh process cpu" I am able to see that 60-70 % CPU is utilized by 'virtual exec proc'.Even I tried to clear the unnecessary telnet sessions with the help of "clear tcp tcb..." but there is no improvement.Please suggest for the same since it is very critical.
BrinksArgentina Sat, 05/30/2009 - 17:37
Maybe a host is doing a DoS attack.
Do you have hosts on the administrative VLAN of the swtichs?
I you do not have a firewall between your hosts, you can filter source IP address for telnet connections.
Example 7-58 illustrates the access list configuration to only allow hosta to telnet to r3.
Example 7-58. ACL Configuration
</p><p>r3(config)#access-list ?</p><p>  <1-99>       IP standard access list</p><p>  <100-199>    IP extended access list</p><p>  <1000-1099>  IPX SAP access list</p><p>  <1100-1199>  Extended 48-bit MAC address access list</p><p>  <1200-1299>  IPX summary address access list</p><p>  <1300-1999>  IP standard access list (expanded range)</p><p>  <200-299>    Protocol type-code access list</p><p>  <2000-2699>  IP extended access list (expanded range)</p><p>  <300-399>    DECnet access list</p><p>  <400-499>    XNS standard access list</p><p>  <500-599>    XNS extended access list</p><p>  <600-699>    Appletalk access list</p><p>  <700-799>    48-bit MAC address access list</p><p>  <800-899>    IPX standard access list</p><p>  <900-999>    IPX extended access list</p><p>  rate-limit   Simple rate-limit specific access list</p><p>r3(config)#access-list 1 ?</p><p>  deny    Specify packets to reject</p><p>  permit  Specify packets to forward</p><p>r3(config)#access-list 1 permit ?</p><p>  Hostname or A.B.C.D  Address to match</p><p>  any                  Any source host</p><p>  host                 A single host address</p><p><b>r3(config)#access-list 1 permit</p><p>r3(config)#access-list 1 deny any log</p><p>r3(config)#line vty 0 4</b></p><p>r3(config-line)#access-class 1 ?</p><p>  in   Filter incoming connections</p><p>  out  Filter outgoing connections</p><p><b>r3(config-line)#access-class 1 in</p><p>r3(config-line)#end</b></p><p>r3#copy running-config startup-config</p><p></p><p>Now test out the ACL as in Example 7-59.</p><p></p><p>Example 7-59. ACL Testing</p><p>sw3512xl#telnet</p><p>Trying ...</p><p>% Connection refused by remote host</p><p></p><p>sw3512xl#ping</p><p>Type escape sequence to abort.</p><p>Sending 5, 100-byte ICMP Echos to, timeout is 2 seconds:</p><p>!!!!!</p><p>Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/3 ms</p><p>
Please rate all the helpful comments.
Leo Laohoo Sat, 05/30/2009 - 19:52
Put a link utilization. It may sound that you have a broadcast storm.
