How to Block communication between two same vlan
irfan_1505
I want block to Pc from communicating in the same vlan
8 Replies 8
mohammedrafiq
Mac access list might also do the trick
cisco_lad2004
Level 5
Level 5
PVLAN are great for this purpose, just keep in mind that they area acting as L2..so if you are using SVI then you need ACL on top of PVLAN.
Danilo Dy
Depends on you switch model and IOS installed, you can use PVLAN as mentioned by Colin.
Here is the matrix of switches and IOS that supports PVLAN http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080094830.shtml
Jayakrishna Mada
You can also use Vlan access-lists (VACL).
Hi jamada,
Can you Vacl configuration with an example.
norman_santana
Hello, thanks for start conversation, the post from the others budies was very usefull for me.
So I would like to ask if somebody test pvlan with catalyst 35XX or 29xX
I'll be expecting for your comments
Norman Santana
Leo Laohoo
If you checked Danilo's link, you will notice that the 2900XL/3500XL cannot support PVLAN.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080094830.shtml#topic1
2900XL/3500XL also cannot support VACL.
Hope this helps.
