05-29-2009 04:23 AM - edited 03-11-2019 08:37 AM
Hello All,
I have noticed for 2 weeks that I have an 85-89 % usage in my ASA 5510.
I have checked teh logs and nothing odd..the number of concurent connections ar about 500-600.
What can I do to decrese teh memnory usage?
Thx
Vlad
05-29-2009 05:20 AM
what code is on the ASA?
Here are some possible causes and resolutions for high memory utilization:
Event logging: Event logging can consume large amounts of memory. In order to resolve this issue, install and log all events to an external server, such as a syslog server.
Memory Leakage: A known issue in the security appliance software can lead to high memory consumption. In order to resolve this issue, upgrade the security appliance software.
Debugging Enabled: Debugging can consume large amounts of memory. In order to resolve this issue, disable debugging with the undebug all command.
Blocking Ports: Blocking ports on the outside interface of a security appliance cause the security appliance to consume high amounts of memory to block the packets through the specified ports.In order to resolve this issue, block the offending traffic at the ISP end.
05-29-2009 05:27 AM
I am running 8.0(4)
I am logging to a syslog !
No deb is enabled.
I am blocking the ports on the outside interface and not at the ISP end.
Thx
Vlad
05-29-2009 05:32 AM
ok..
there is an open caveat for the version you're on.
search for CSCsq78576 under this URL http://www.cisco.com/en/US/docs/security/asa/asa80/release/notes/arn804n.html#wp250917
05-29-2009 05:44 AM
Thanks a lot!
This is teh code
"disk0:/asa804-28-k8.bin
Which one should I upgrade to? I have just upgraded to this one due to some vulnerabilities!
Vlad
05-29-2009 06:02 AM
Vlad,
i cant recommend a code version to you but if you have access to cisco site, check the software download link below for latest releases. The latest code is 8.2.1 i believe but i'm not sure how reliable that code is....
http://www.cisco.com/cgi-bin/tablebuild.pl/asa
Francisco.
06-04-2009 12:20 PM
Latest in the 8.0.x
I am unable to recommend code either.
http://www.cisco.com/cgi-bin/tablebuild.pl/asa-interim
asa804-31-k8.bin (file names)
