National Number Prefix - LATA, Intra-LATA numbers
May 29th, 2009
We have found where we can implement national number dialing prefix in service paramaters and adding 91 to the inbound caller-id works for the most part. Our service, however, is on PRI that support both local and LD calls on the same lines.
Our LEC does not allow us to dial 1 for a local or intra-lata call that is not actually LD. Calls that are from local or metro exchanges must be dialed without a 1.
Is there a way to implement this and create an exception for 'local' area codes?
We are on CCM 4.1.3 SR5d
Dennis Mink Fri, 05/29/2009 - 09:26
Used your route patterns to do digit stripping for outbound calls. gimme some examples and I will explain how to do it
