Cisco Security Manager: how to add "dialer pool-member" in ATM interface
Answered Question
May 29th, 2009
I have a ISR 1801 with an ADSL interface.
Do you know where I can add dialer pool-member configuration for an ATM interface in CSM ?
I've tried lost of things including a config discovery without success.
CSM is always deleting this line. And the realtime result is always the same:
bye-bye router (needs to reboot it to restore original configuration).
Any idea ? (except stop using the bugy CSM)
NH
Correct Answer by drolemc about 7 years 10 months ago
1. Enters interface configuration mode for the ATM interface.
2. Creates an ATM PVC for each end node (up to ten) with which the router communicates. Enters ATM virtual circuit configuration mode. When a PVC is defined, AAL5SNAP encapsulation is defined by default.
3. Specifies the ATM interface as a member of a dialer profile dialing pool. The pool number must be in the range of 1-255.
Overall Rating: 5 (1 ratings)
Correct Answer
drolemc Thu, 06/04/2009 - 07:04
  • Silver, 250 points or more
