francisco_1 Fri, 05/29/2009 - 06:41
  • Gold, 750 points or more
The minimum software version required before upgrading to PIX Version 8.0(2) is PIX Version 7.2. If you are running a PIX version earlier than Version 6.2, you must first upgrade to PIX Version 6.2 or PIX Version 6.3 before you can upgrade to PIX Version 7.2.
joerggrau Fri, 05/29/2009 - 06:52
I am aware of that, but I need to know if the licenses will transfer without a hitch. I will upgrade them each in one maintenance window, so having to renew licenses I would want to do ahead of time.
Correct Answer
francisco_1 Fri, 05/29/2009 - 06:56
no need for licenses renewal..
