internet access
hi! i've 2 6509(catos) with 2 links that are connected to our corporate office. Currently we encounter slow internet access for vlan that go throuth core2 wherease it's fast for those vlan that go through core1. Within our intranet, access to our internal portal is fast. So it's defintely no issue wiht the internal network.
i also did a traceroute to our corporate proxy and it's able to hit the proxy (for both core 1 n 2) wihout any delay.
when i disable the port on our core 2 that's connected to our corporate switch (LAN), all the PCs are automatically switch over to go through the link on core1 n internet access is fast.
I've also checked the bandwidth utilization for both of our link to our corporate sw, utilization is low. all the modules and interface are with ok status.
This actually happened previously, and it worked fine after i resetted both the core sw + sometimes by shutting down and no shut for the vlan interface for the 2 link to corporate sw, but it doesn't seems to work this time.
can anyone advise on how can i troubleshoot on this?
John Blakley Fri, 05/29/2009 - 07:30
What do you get when you traceroute out of your network to an external destination? Does your core2 router have the same default route, or does it go through a different ISP?
hi! I'm not able to see which isp does it goes to as it's from the corporate side. I do understand that there are about 5 "sites" (we are one of them) that are connected to the corporate which then shared the 2x wan outgoing link to the internet with 2 different isp, but so far only us have this problem. So, i don't think it's their proxy or isp issue.
Richard Burts Sat, 05/30/2009 - 08:03
What kind of link is it that connects your site to the central site? Is it the same through both of your switches? Is there a possibility of transmission errors on the link from switch2?
If you go from your site to one of the other sites, and if you force that traffic to go through your switch2 is that also slow? (is it just Internet that is slow or is everything slow that goes through this switch?)
Can you check for packet loss on the interfaces you go through when you go through switch2? Can you check for possible duplex mismatch on these interfaces?
hi! Rick
our cores are connected to the central office through 2 fiber links (1 link from each core), thus yes, both the links are the same which is fiber. I checked the msfc on core 2 by using the sh interface command, there's no errors or crc logged. As for the sw, what command can i use? the 6509 sw is running on catOS. Not too familiar with the CatOS command.
So far, for this link to our main office from this pair of 6509 is only for internet access. For access of corporate portal,email or app is through another core. We can;t access the corporate app from this core sw. So no way to test.
i tried to do a ping to the proxy seesm normal the reply is consistent. time<1ms. We're confirmed that there isn't any mismatch. I did a sh port 9/9 It's full duplex with speed 1000.
In the core 2 sw, i saw a command to show errordetecion? it's currently disabled? Can i enabled it? will it help to troubleshoot?
Pls advise again. Thanks
hi! I used the command sh port and here's the msg output. It seems that...there isn't any error as well.
Port Name Status Vlan Duplex Speed Type
9/9 to-Corp2 connected 82 full 1000 1000BaseSX
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
9/9 disabled shutdown 0 0 1 disabled 36
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
9/9 0 - - - - -
Port Broadcast-Limit Multicast Unicast Total-Drop Action
9/9 - - - 0 drop-packets
Port Send FlowControl Receive FlowControl RxPause TxPause
admin oper admin oper
9/9 desired off off off 0 0
Port Status Channel Admin Ch
Mode Group Id
9/9 connected auto silent 35 0
Port Status ErrDisable Reason Port ErrDisableTimeout Action on Timeou
9/9 connected - Enable No Change
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
9/9 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
9/9 0 0 0 0 0 0 0
You could have someone flooding the link between core2 and yours corporate office. Have you already checked for errors between these interfaces? What kind of interfaces are we talking about?
Can you better explain your setup ? Perhaps do quick draft showing it's really connected and what are the internet links. Also, how about QoS? have you been doing anything either on core 1 or core 2?
hi!...I checked out network monitoring tools on the port 9/9...the traffic is only 2-3mbps. So, the link is not flooded. There isn't any errors on our end...and the corporate side also told us their interface is ok too.
each core has 2 sups and mod 9/9 is connected to the corporate through 1 fiber link...1 links from each core sw to 2x core sw at corp - 1 to 1 connection
Each of this routers are configured with different vlans (eg. vlan 5,6 in c1r1, vlan 7,8 in c1r1). some of the vlans will go through 9/9 of core 1 to the corp 1 core and some of the vlans will go through 9/9 of our core 1 to corp 2 core. (c1r1 above means core1 router1)
The link to the corp 1 are configured with 2 vlans 82, and 81.
hi! Here's the drafted diagram. Thanks.
i've also found the following errors
corp2> (enable) sh counters supervisor
Forwarding Engine Error Stats Counters
IP len against Physical length err = 0
IP min. length check error = 0
IP pkts with cksum error = 4
IPX len against Physical length err = 0
IPX min. length check error = 0
Routers/sup (all the 4 sups)
%MROUTE-4-MTU_MISMATCH: WARNING: With IP multicast enabled, in
terfaces which transmit traffic from larger to smaller MTU interfaces may not be
hardware switched due to fragmentation. A degradation in performance may occur.
