Automatic DNS entries for routers-can it be done?
May 29th, 2009
  • Purple, 4500 points or more
All,
Let me throw this out there as I don't think it can be done, but curiosity got me. Can I have my routers automatically register with DNS like a normal workstation does, or do they have to be manually configured?
John
Edison Ortiz Fri, 05/29/2009 - 07:39
  • Hall of Fame,
    Founding Member
manually configured.
Jon Marshall Fri, 05/29/2009 - 07:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
I'm not sure now that Edison has posted.
I was under the impression that you could do this assuming your router is using DHCP to set the interface address. If you hardcode the address then no it can't be done -
http://www.cisco.com/en/US/docs/ios/12_3/12_3y/12_3ya8/gt_ddns.html
Jon
Edison Ortiz Fri, 05/29/2009 - 07:48
  • Hall of Fame,
    Founding Member
Jon,
Yes, with DHCP can be done along with DDNS but that's useful on PPPoE Client or Cable Modem scenario. I think John was more inline of router name discovery on an enterprise network.
This process is done manually.
John Blakley Fri, 05/29/2009 - 07:54
Thanks Jon/Edison. I wouldn't be using DHCP, so it would need to be like automatic registration when Windows joins the domain. I was wondering if there was a command on the router that would allow me to register with the dns servers that are listed (internal servers) on the router and it would automatically register the hostname and domain name that was configured on the router.
Maybe they could put it in a future release ;-) (I could also see it as a security risk too though.)
Thanks!
John
pompeychimes Fri, 05/29/2009 - 09:49
  • Bronze, 100 points or more
I'd love this functionality. Would be similar to the "ip ddns update" command.
