Cisco IDS/IPS OS and Application Identification?
May 29th, 2009
I'm researching IPS solutions for a client - one of the requirements that's important to them is the ability of the system to identify the OS and applications associated with individual hosts or clients. The intent would be to use this information in triaging and responding to alerts. I don't see that this capability is provided - but am wondering if anyone knows otherwise.
Thanks.
Farrukh Haroon Sat, 05/30/2009 - 05:51
  • Red, 2250 points or more
The Cisco IPS can do this. You can even integrate with the Management Console for the Cisco Security Agent CSA (HIPS) to get accurate host fingerprint(s). Have a look at:
http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliExPrd.html
The auto-detection does not always do a good job, and you need to set things manually.
http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliEvAct.html#wpxref72157
Please rate if helpful
Farrukh
