how to configure AIM-IPS module on 4215?
May 29th, 2009
my manager is installing a 4216 -w- 6.0 code. He is asking for whitepages on how to configure the 4-port module card. I'm not having any luck with locating "configuration" paper on this. Are there any instructions for this?
thanks, Kevin
Farrukh Haroon Sat, 05/30/2009 - 05:45
  • Red, 2250 points or more
Are you looking for hardware installation or software?
The AIP-IPS module goes into routers and not sensors as your topic post states.
Are you looking to install a 4FE card or an AIM-IPS into a router?
The Hardware installation guide is here:
http://www.cisco.com/en/US/docs/security/ips/7.0/installation/guide/hw_installing_aim.html
For the 4FE card, the software configuraiton is just like any other module, there is no special configuration for the interfaces (they are just like the built-in sensing interface).
Farrukh
