Fractional PRI E1 Configuration help
Answered Question
May 29th, 2009
I am facing issues, unable to dial out using the E1.
I have configured Fractional PRI E1 on Cisco 3845, as follows:
controller E1 0/3/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-8,16
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
dial-peer voice 3 pots
translation-profile incoming PSTN
destination-pattern 9T
direct-inward-dial
port 0/3/0:15
Upon running isdn q931 debug, i get the below:
*May 29 17:45:00.123: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x0 0x1, Called num 0XXXXXXXXXX
*May 29 17:45:00.123: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A2
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Called Party Number i = 0x81, '0XXXXXXXXXXX'
Plan:ISDN, Type:Unknown
*May 29 17:45:00.311: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x
80A2
*May 29 17:45:00.311: ISDN Se0/3/0:15 **ERROR**: call_setup_ack_proceeding: NO H
DLC available b channel 7 call id 0x800B
*May 29 17:45:00.311: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0
x00A2
Cause i = 0x80A2 - No circuit/channel available
*May 29 17:45:00.503: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x80
A2
*May 29 17:45:00.503: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x00A2
Please suggest.
Correct Answer by paolo bevilacqua about 7 years 11 months ago
As I've explained you above, it is normal for isdn test call to fail because no HDLC resources. This is because to process data calls, you need a special configuration not needed for voice calls.
Again, as explained before, the command to use is csim start .
Use the clock configuration that I've indicated and you will have no problems.
Please remember to show your appreciation for experienced professionals of this forum using the scrollbox below.
Overall Rating: 4.3 (4 ratings)
paolo bevilacqua Fri, 05/29/2009 - 13:56
  • Hall of Fame,
    Founding Member
This is a data call:
How did you generated it ?
Adrian Saavedra Fri, 05/29/2009 - 14:49
  • Gold, 750 points or more
Hi friends,
I have seen Unrestricted Digital when doing calls from IP Phones with VideoCapabilities (Cisco 7985 or IP PHone with CUVA) to PSTN.
Configuring bearer-cap speech under voice-port should fix any problem with calls to PSTN from this type of endpoints.
Best regards,
- Adrián.
csshenoy80 Fri, 05/29/2009 - 18:02
Does it mean the configuration is incorrect, as the requirement is to configure 8channel ISDN PRI E1 Voice channels.
This call was generated using isdn test call command from the Cisco 3845 router.
Thanks.
paolo bevilacqua Fri, 05/29/2009 - 18:05
  • Hall of Fame,
    Founding Member
The configuration is correct.
isdn test call generates digital calls that are normally failing on a voice configuration.
With a normal dial peer configuration, you can use csim start for test calls.
Also remember to configure network-clock-participate and network-clock-select for the interface.
Finally, please remember to rate useful posts with the scrollbox below.
csshenoy80 Fri, 05/29/2009 - 18:14
the isdn test call command is supposed to make dummy calls to the destination number, and call must be connected. please correct me if i am wrong.
My concern is I am getting the errors for No channel / circuit avialable and No HDLC available in the q931 debugs.
Thanks.
Thanks.
Correct Answer
paolo bevilacqua Fri, 05/29/2009 - 18:48
  • Hall of Fame,
    Founding Member
