Unity Message Addressing mode
May 29th, 2009
Hello Experts,
When Subscribers are to forward a voicemail or send a message the defaulf message addressing option is search by name.
We can change that to search by extension by selecting the subscriber -> conversation -> Message Addressing option
Is there a global setting to configure that for all subscribers at unity? (system wide config)
Thank you!
rob.huffman Fri, 05/29/2009 - 12:55
Hi Luisa,
This can be changed on the Template Level as well, but you will still run into this restriction;
Note: that changes to settings in a template do not affect any of the existing subscriber accounts that were based on that template. This will only take effect for "new" users created after the Template is changed, so you may want to use Bulk Edit.
Subscriber Template Conversation Settings
Identify A Subscriber By Select how subscribers address messages to other subscribers. Subscribers can address messages over the phone by entering subscriber extensions, by spelling their first names, or by spelling their last names. Addressing by name requires lettered keypads on subscriber phones.
In the subscriber conversation, subscribers can switch between addressing by name and addressing by extension by pressing the # key twice. Note that when the Enable Spelled Name Search check box is unchecked on the System > Configuration > Settings page, subscribers can address messages over the phone only by entering subscriber extensions.
Hope this helps!
