Mobility Advantage in lab environment
Answered Question
May 29th, 2009
We recently purchaseD the UC 7.0 NFR software for our test lab. Is there any reason that we would not be able to test CUMA/mobile communicator with only a single analog line for PSTN connectivity? Is there any reason that a PRI is required (as is the case with mobile voice access feature with ucm)?
thank in advance,
Correct Answer by Brandon Buffin about 7 years 7 months ago
The only thing I can think of that this setup would prevent you from testing is an external call that rings a mobile phone as this would require 2 lines - one for the incoming call, one for the outgoing call to the mobile.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Fri, 05/29/2009 - 11:43
Brandon
