Cisco IOS SSL VPN questions
May 29th, 2009
I have two questions.
1. Is there any way to implement IOS SSL vpn through PAT'ing off of a single public IP address?
I've gotten this to work fine without PAT but with PAT I've had issues so I wanted to know if its possible or not possible.
2. Is there any way to set the webvpn gateway to be identified by a hostname instead of setting an IP address for the "Virtual IP Config"?
Basically what I'm trying to do, is figure out if its possible to use a DNS name instead of a static IP, because if it's possible to use a DNS name (in the place of an IP), then you can use DHCP on your WAN interface.
Web VPN config below--------------
webvpn gateway WVPN_1
ip address 1.1.1.1 port 443
ssl trustpoint TP-self-signed-3998510203
inservice
webvpn install svc flash:/webvpn/svc.pkg
webvpn context TEST1
title-color #CCCC66
secondary-color white
text-color black
ssl authenticate verify all
policy group policy_1
functions svc-enabled
svc address-pool "VPNPOOL1"
svc default-domain "domain.dyndns.org"
svc keep-client-installed
default-group-policy policy_1
aaa authentication list XAUTH
gateway WVPN_1 domain TEST1
max-users 2
inservice
end
System image file is "flash:c1841-adventerprisek9-mz.124-9.T4.bin"
Overall Rating: 3 (1 ratings)
Farrukh Haroon Sat, 05/30/2009 - 06:28
I don't think DHCP is supported, you can easily verify it by doing a question mark on the ip address command in webvpn gateway configuration mode.
IF your internet link is not terminated on the router itself, you could use some upstream device that supports DHCP (on interfaces) to do NAT. But I don't think this is the case for you.
Farrukh
