Changed Dialed Number displayed on phone
May 29th, 2009
I have prepended access codes to my outbound pots dial peers, so that i can selectively match which port is used. The access code is now displayed on the phone, such as 391XXX-XXX-XXXX. Is there a way to change what is displayed on the phone? thx
paolo bevilacqua Fri, 05/29/2009 - 18:54
  • Hall of Fame,
    Founding Member
Are you using CME or CCM, and which version ?
balitewiczp Fri, 05/29/2009 - 20:21
CCM 4.2
i will be moving to cm7 in a few months, please comment if it is different in cm7
thanks
