Will Unity 4.x support exchange 2007?
May 29th, 2009
We currently have Unity 4.x integrated with Exchange 2003 for Voicemail, we are planning an upgrade of Exchange to 2007. I was wondering if there are any compatibility issues we should be concerned about. Also should we be thinking about upgrading Unity before Exchange?
Overall Rating: 4 (1 ratings)
Rob Huffman Fri, 05/29/2009 - 16:38
Hi Augustine,
Support for Exchange 2007 was nut added until Unity 5.x, so you would need to upgrade to at least 5.x;
Cisco Unity 5.0 for Microsoft Exchange
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_data_sheet0900aecd805e6e12.html
Use the Installation Guide That Matches the Cisco Unity 5.x Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/correct_ig/5xcuigcrct.html
Exchange Requirements-Message Store Unity 4.2(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/requirements/42cusysreq.html#wp472166
Hope this helps!
Rob
