Mapping a Button on a 7960 for incomming calls only from FXO Port
May 29th, 2009
Can anyone advise on the proper config to direct incoming call on an FXO port to be mapped on a button on a 7960? also I have an active sip trunk which i would not want to be affected by this addition.
paolo bevilacqua Fri, 05/29/2009 - 18:01
  • Hall of Fame,
    Founding Member
Are you using CME or CCM? If the latter, MGCP or H.323 ?
Dennis Mink Sat, 05/30/2009 - 05:40
  • Gold, 750 points or more
you want an incoming call to your FXO port, to ring on your 7960?
just add an extension to your phone that corresponds with the number on your FXO port or whatever you want to use for it
