Vlan-Bridging
May 29th, 2009
Hi, I have one L2 switch having two vlan 4 & 5. I want communication between host of both vlans. How it can possible? Although I have configured Vlan-Bridge, but it is not working
interface Vlan4
bridge-group 1
interface Vlan5
bridge-group 1
bridge 1 protocol vlan-bridge
Giuseppe Larosa Sat, 05/30/2009 - 08:26
  • Hall of Fame,
    Founding Member
Hello Rupesh,
vlan bridging can help if users on vlan4 and vlan5 are in the same IP subnet otherwise you need a router.
IPv4 doesn't allow two hosts in two different IP subnets to talk to each other directly.
To be noted that IPv6 allows this.
About vlan bridging each vlan needs to have at least one L2 port in STP forwarding state.
Hope to help
Giuseppe
rakesh.hegde Sun, 05/31/2009 - 12:20
Hi Rupesh,
Fallback bridging bridges traffic that the switch can not route. For example, you can bridge IPV6 on a 3550 since it can not route IPV6.
HTH,
-Rakesh
Giuseppe Larosa Mon, 06/01/2009 - 02:10
  • Hall of Fame,
    Founding Member
Hello Rakesh,
other platforms like C6500 can perform vlan bridging for ipv4 by adding
bridge-group 1 bridge ip
C3550 and probably other C3x50 behave like you have described
Hope to help
Giuseppe
rakesh.hegde Mon, 06/01/2009 - 13:11
Hi Giuseppe ,
You are right. 6500 behaves more like a router when it comes to bridging. Unlike Fallback bridging, we need to enable IRB to get it working. The command bridge-group <> bridge ip is enabled by default.
-Rakesh
