cue error questions
May 29th, 2009
guys,
i updated my uc520 through cca to the latest, 7.1. for some reason whenever i login to cue and try to modify the extension, and i am getting this kind of error.
Configure > Extensions
Site Name:local
Error: Unable to login as administrator to the Cisco CallManagerExpress at site 'local'.
Details: CME login failed
but i don't see a problem when i login to cme site. also another thing my clock isn't synchronized to cme. fyi: i have t1 configured for my voice.
Reports > Network Time Protocol
HelpHelp
#NTP ServerStatusTime Difference (secs)Time Jitter (secs)
110.1.10.2reject0.04.0
is it possible there is something to do with compatibility issue?
thank you for your help
Tedy Nugroho Tue, 06/02/2009 - 10:21
it was something to do with the credential that is used on the CME. On the telephony-service config, the credential info has to be same as CUE.
As far as the NTP server issue, I have to use the external IP address not the CME IP address.
