05-30-2009 01:26 AM - edited 03-09-2019 10:19 PM
In th HQ, I have a Cisco router connected to a security equipment (Crypto AG) that encrypt all the packet (including the header), the security equipment is connected to another Cisco router which is connected to IP/MPLS or Frame Relay Provider.
CISCO <---> SEC. EQUIPMENT <---> CISCO <---> PROVIDER
In the branch office, I have the same architecture.
Is there any why to make this architecture work (can ping from the 1st router in HQ to second router in branch office) ?
I was told that we can use PAD (packet assembler/disassembler) to communicate between the 2 routers in the same site
any advice will be helpfull.
thanks in advance.
Lamine
06-04-2009 11:23 AM
You can create Frame Relay connections using one of the following hardware configurations:
â¢Routers and access servers connected directly to the Frame Relay switch
â¢Routers and access servers connected directly to a channel service unit/digital service unit (CSU/DSU), which then connects to a remote Frame Relay switch
Routers can connect to Frame Relay networks either by direct connection to a Frame Relay switch or through CSU/DSUs. However, a single router interface configured for Frame Relay can be configured for only one of these methods.
06-04-2009 12:32 PM
many thanks for your reply.
the problem is that the Security device works in Layer 1, it encrypt all the packet including the L2, L3 header, which means that the cisco router doesn't know how to forward the packets received from it's connection with the security device to the other side.
Lamine
