adding conference bridge to CUCM 6.1
May 30th, 2009
Maybe someone has done this before:
At the moment it's not possible to make conference calls with external (over pstn) useres with CUCM 6.1. I have a 7206VXR Router (H.323 Gateway) with a PA-VXA-1TE1-30+ and a PA-VXC-2T1E1+ card in it. Last one has 30 DSPs on it. I want to add a IOS conference bridge to Callmanager using that DSPs on the 7206VXR router to allow conferencing and transcoding.
Callmanager Version is 6.1
IOS Version is 12.4.25 (IP)
What settings do I have to use on callmanager and what do I have to configure on the router?
Thanks in advance!
Overall Rating: 4 (1 ratings)
David Schwarzhans Sat, 05/30/2009 - 06:06
part of it, yes. I started with this:
Gateway#configure terminal
Gateway(config)#sccp local FastEthernet 0/0
Gateway(config)#sccp ccm >IP< priority 1
but it is not possible to enter any command starting with "sccp".
Could it be, that I only have to configure the dspfarm part and then the system is intelligent enough that it uses the dsp resources on the gatway for conferencing?
Jaime Valencia Sat, 05/30/2009 - 16:43
Prerequisites for Conferencing and Transcoding for Voice Gateway Routers
DSP Resources
The router must be equipped with one or more of the following network modules or voice DSP modules to provide DSP resources for conferencing, transcoding, and hardware MTP services:
•PVDM2 on Cisco 2800 series or Cisco 3800 series
Cisco CallManager and Cisco IOS Interoperability Guide
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
Table 25-1 Conference Bridge Types
if this helps, please rate
David Schwarzhans Sun, 05/31/2009 - 02:22
Ok, that helps. If I understand it correct, it is not possible to add a IOS conference bridge to Callmanager if not one of the above DSP Modules is installed on the router. Right?
But how can I use the 30 DSPs that are on the PA-VXC-2T1E1+ card? Are they useless? Or is it somehow possible to configure them that conferencing could still be enabled in this voice network with the given hardware?
David Schwarzhans Tue, 06/02/2009 - 00:09
Ok, here is the confirmation from TAC Engineer:
I checked on this and found that the PA can use their DSPs only for voice termination
As per the information I have from 2003
“ The 7200 platform cannot natively use its DSPs for transcoding or conferencing. I have checked
same and indicating that there is nothing currently on the roadmap to support this.
The customer will have to offload the transcoding and conferencing function to another site with C5510-based or NM-HDV C549-based DSPfarms.“
