configuring IOS firewall Zone Based --> remotely
May 30th, 2009
Hi to all,
need to deploy the folling IOS firewall Zone Based configuration to a running remotely router.
I'M CONNECTED WITH SSH ...
HOW IS IT POSSIBLE WITHOUT DISCONNETING ME ?
class-map type inspect match-any untrust-trust-cmap
match protocol telnet
match protocol ssh
policy-map type inspect untrust-trust-pmap
class type inspect untrust-trust-cmap
inspect
class class-default
class-map type inspect match-any trust-untrust-cmap
match protocol tcp
match protocol udp
policy-map type inspect trust-untrust-pmap
class type inspect trust-untrust-cmap
inspect
class class-default
zone security trust
zone security untrust
zone-pair security trust-untrust source trust destination untrust
service-policy type inspect trust-untrust-pmap
zone-pair security untrust-trust source untrust destination trust
service-policy type inspect untrust-trust-pmap
interface FastEthernet0/0
zone-member security trust
int dialer 0
zone-member security untrust
interface ATM0/0
Roberto Taccon
plumbis Mon, 06/01/2009 - 21:34
  • Silver, 250 points or more
This is always very risky. I would suggest that you issue the "reload in " command before trying to configure any interfaces as zone-members. I would stage the entire policy-map based configuration first, then I would configure the zone-member pairs in the "inside", "outside", "self" order, but there is 0 guarantee this will work. If you do lock yourself out the "reload in" command will reload the router and you can ssh back to the box after it finishes rebooting.
good luck!
ROBERTO TACCON Tue, 06/02/2009 - 06:17
thanks for the info (I know the reload command and also the rollback command).
Q1) When I try to insert on the 1st interface the "zone-member security trust" or "zone-member security untrust" I LOST THE ROUTER CAUSE THE OTHER INTERFACES ARE NOT CONFIGURED: HOW I CAN ACTIVATE THE ZONE-MEMBER COMMAND ON THE ROUTER WITHOUT LOST IT ?
Q2) it's possible (like Juniper JUNOS) made alla the new configuration and execute the "commit now" when I've finished ?
Q3) Is there any other feature on cisco IOS to allow to configure the router, check the configuration and only AFTER put it on the running config (the only tip i?ve found is to modify the startup config and load in or merge the running config with another conf...)?
Using Cisco Config Rollback
Replace the Running Configuration with the Latest Good Archive After Two Minutes Unless the Change Being Made Is Confirmed
Router#show archive
There are currently 4 archive configurations saved.
The next archive file will be named disk0:/config-archive-4
Archive # Name
1 disk0:/config-archive-1
2 disk0:/config-archive-2
3 disk0:/config-archive-3 <- Most Recent
Router#config replace disk0:/config-archive-3 time 120
If the configuration was successful, apply the changes
Router#config confirm
• If the config changes caused the user to be locked out, the router will automatically revert to the last saved archive configuration after two minutes, and connectivity will be restored
Roberto Taccon
