CUCM Cluster Not sync
For every server, shows if you can read from the local and publisher databases.
Local and publisher databases accessible.
View Details
Server Publisher DB Reachable Local DB Reachable
192.168.97.10 true true
192.168.97.11 true true
Unified CM Database Status Shows if replication is good or bad.
RTMT Counter Information
All servers do not have a replication count of 412.
Not all servers have a good replication status. See the details.
View Details
Server Number of Replicates Created Replicate_State
192.168.97.10 412 4 - setup failed
192.168.97.11 0 0 - initializing
Server Host Information
192.168.97.10
#This file was generated by the /etc/hosts cluster manager.
#It is automatically updated as nodes are added, changed, removed from the cluster.
127.0.0.1 localhost
192.168.97.10 ccm-pub.uccisco.com ccm-pub
192.168.97.13 CUPS.uccisco.com CUPS
192.168.97.11 ccm-sub.uccisco.com ccm-sub
192.168.97.11
127.0.0.1 localhost
Tommer Catlin Mon, 06/01/2009 - 06:34
  • Green, 3000 points or more
Check your NTP time is insync on the publisher.
Sometimes simply rebooting the publisher and or the subscriber will get it back. If it's a new setup, and you have wasted more than 4 hours trying to fix the subscriber, reload it. It only takes 1-2 hours to reload it and set it backup.
