dial-peer question
May 30th, 2009
This is a very simple question but somehow I was not able to get a satifactory answer anywhere.
I have a H323 gateway with a voip dial-peer for the destination pattern "25977." and also a ".T" dial peer.
When the CallManager routes a call to extension "25977" to the gateway which dial-peer (25977. or .T) will be matched?
Please note that the dialed number is 5 digit and the dial-peer on the gateway is 6 digit and .T
gogasca Sun, 05/31/2009 - 00:22
will use .T, since it is an enbloc call.
GW gets all the digits not one by one.
which one is matching?
