CUCM 7: Dial out to PSTN gives busy
May 31st, 2009
I am configuring H323 GW with CUCM7. Have the required gateway configuration with dial-peer pots:
dial-peer voice 100 pots
destination-patter 9T
direct-inward-dial
Port 0/1/0:15
Also have the Route pattern configured for international 9.00!.
The isdn q931 gives the below message:
*May 31 11:47:09.336: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x0 0x0, Calling num 0XXXXXXXXXXX
*May 31 11:47:09.340: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x0 0x0, Called num 00YYYYYYYYYYYYY
*May 31 11:47:09.340: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0136
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '0xxxxxxxxxx'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '00yyyyyyyyyyyyy'
*May 31 11:47:09.524: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x
8136
Progress Ind i = 0x8288 - In-band info or appropriate now available
*May 31 11:47:09.552: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0
x0136
Cause i = 0x80AC - Requested circuit/channel not available
*May 31 11:47:09.700: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x81
36
*May 31 11:47:09.704: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x0136
Kindly suggest.
Overall Rating: 3 (2 ratings)
paolo bevilacqua Sun, 05/31/2009 - 06:40
  • Hall of Fame,
    Founding Member
Router disconnects, that is not normal.
Which exact IOS is this ?
csshenoy80 Sun, 05/31/2009 - 07:09
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(11)XJ4
, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
paolo bevilacqua Sun, 05/31/2009 - 07:33
  • Hall of Fame,
    Founding Member
That should not happen. Perhaps is related o something on the h.323 side, check with "debug ccapi all".
csshenoy80 Sun, 05/31/2009 - 07:44
the debug ccapi all is not supported on the cisco router. Any other config / debug which need to be checked.
paolo bevilacqua Sun, 05/31/2009 - 07:49
  • Hall of Fame,
    Founding Member
It should be supported, or some variation of debug ccapi.
csshenoy80 Sun, 05/31/2009 - 07:57
it has "debug voip ccapi", also, I am able to dial out local numbers, only international numbers are giving me busy tone.
The international numbers get dialed out using the "csim start" command.
I have checked the route patterns and they seem to be fine.
Please suggest.
Jaime Valencia Sun, 05/31/2009 - 08:50
  • Cisco Employee,
  • Hall of Fame,
    2011
Exactly what is telco expecting for these values:
leading 00s?
no 00s but international?
00s + unknown?
00s + national?
If u don't know call your telco, many expect a combination of parameters to allow the calls
java
if this helps, please rate
csshenoy80 Sun, 05/31/2009 - 09:00
BT is the telco. As well, I have configured the DID.
The telco is sending 6 digits on the gateway. On CUCM H323 Gateway, I have configured the significant digits as 4, with CSS which has access to the IP Phone partitions, but when i dial the DID number form PSTN, I get the announcement, number not in use. As well, from q931 debug, i get the message , unallocated number.
Please suggest.
Ayodeji Okanlawon Sun, 05/31/2009 - 09:35
  • Cisco Designated VIP,
    2017 IP Telephony
Un allocated number is usually a CSS/partiton problem
two things
1. Check the CSS on your gateway that it has the partition of the Phones in it.
2. Post the output of your debug voip ccapi inout here..
If you are using h.323, you need to check your dial-peer config. You can post that here too and I can have a look
csshenoy80 Sun, 05/31/2009 - 10:13
The css on gw has the access to ip phone partiton.
attached is the ccapi debug for DID incoming call, in which the call failed.
I tried with translation pattern as well with all 6 digits coming form the service provider, it didn't help either.
Please suggest.
Ayodeji Okanlawon Sun, 05/31/2009 - 10:29
    2017 IP Telephony
Ok..So here is your problem...
dest=222088
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*May 31 17:53:44.091: //-1/D136EACF803C/CCAPI/cc_api_call_setup_ind_common:
Interface=0x68742DF8, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Scree
ned, Presentation=Allowed),
Called Number=222088(TON=Unknown, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl
ag=TRUE,
Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=-1
*May 31 17:53:44.091: //-1/D136EACF803C/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed)
*May 31 17:53:44.095: //-1/D136EACF803C/CCAPI/ccCheckClipClir
May 31 17:53:44.099: //136/D136EACF803C/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca
use=0)
from the debug..the number called is 222088...The debug shows that there is no dial-peer for this pattern.
You need to have two call legs. In the debug we can only see the incoming dial-peer, we did not see the outgoing dial-peer which the gateway will use to route the call to callmanager.
What is the extension of the phone you are trying to reach? is it 222088?
Can you post your sh run here?
csshenoy80 Sun, 05/31/2009 - 11:00
please find the sh run below:
Building configuration...
Current configuration : 2692 bytes
version 12.4
hostname TESTRTR
boot-start-marker
boot-end-marker
card type e1 0 3
enable password ***********
no aaa new-model
network-clock-participate wic 3
ip cef
isdn switch-type primary-net5
voice-card 0
codec complexity high
dspfarm
dsp services dspfarm
voice call disc-pi-off
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
h225 timeout tcp establish 3
call start fast
voice translation-rule 1
rule 1 /222080/ /8001/
rule 2 /222081/ /8002/
rule 3 /222082/ /8003/
rule 4 /222083/ /8004/
rule 5 /^\(222\)\(...\)/ /2\2/
voice translation-profile PSTN
translate called 1
username TEST
username TEST1 secret 5 **************************!
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-8,16
vlan internal allocation policy ascending
interface GigabitEthernet0/0
ip address X.X.X.X 255.255.255.0
duplex auto
speed auto
media-type rj45
no keepalive
standby 0 ip Y.Y.Y.Y
h323-gateway voip interface
h323-gateway voip bind srcaddr X.X.X.X
interface GigabitEthernet0/1
ip address X.X.X.X X.X.X.X
duplex auto
speed auto
media-type rj45
no keepalive
interface FastEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip http server
no ip http secure-server
control-plane
voice-port 0/3/0:15
dial-peer voice 1 voip
preference 1
destination-pattern 8...
voice-class codec 1
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
no vad
dial-peer voice 3 pots
translation-profile incoming PSTN
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/3/0:15
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password ********
login
scheduler allocate 20000 1000
end
Ayodeji Okanlawon Sun, 05/31/2009 - 11:07
    2017 IP Telephony
Ok,
Your translation rule does not have the pattern for the dialled number.
The dialled number is 222088.
So you need a rule for 222088
csshenoy80 Sun, 05/31/2009 - 11:14
you mean rule to convert 222088 to 2088? I already have the voice translation to convert 222088 to 2088. kindly suggest.
Ayodeji Okanlawon Sun, 05/31/2009 - 12:24
    2017 IP Telephony
Your xlue is a bit awkward and thats why its noit matching on the dialled number.
Try and configure rule for /222088/ /2088/
specifically and then test again or change the the rule 222... to be the first rule.
csshenoy80 Sun, 05/31/2009 - 12:30
ok, let me try this out. As well, we would need to have a translation rule on ccm to convert 222088 to 2088?
Would it be a better idea to ask the ISP to send 4digits instead of 6?
Kindly suggest.
Ayodeji Okanlawon Sun, 05/31/2009 - 14:15
    2017 IP Telephony
You can set significant digits on CCM to 4.
That way CCM will strip 222088 down to 2088. But you will need to change your dial-peer to 222... instead of 2...
paolo bevilacqua Sun, 05/31/2009 - 14:16
  • Hall of Fame,
    Founding Member
I don't think this has to do with telco or translation rules.
Router is disconneting the call without apparent reason and without eany error from telco:
x0136
I'm not sure why this happens but it should be a CCM issue.
Ayodeji Okanlawon Sun, 05/31/2009 - 14:29
    2017 IP Telephony
Paolo,
did you go through this debug..
*May 31 17:53:44.091: //-1/D136EACF803C/CCAPI/cc_api_display_ie_subfields:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=222088
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
ag=TRUE,
E), Call Id=-1
ation=Allowed)
*May 31 17:53:44.095: //-1/D136EACF803C/CCAPI/ccCheckClipClir:
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen
tation=Allowed)
*May 31 17:53:44.095: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 31 17:53:44.095: :cc_get_feature_vsa malloc success
*May 31 17:53:44.095: cc_get_feature_vsa count is 1
*May 31 17:53:44.095: :FEATURE_VSA attributes are: feature_name:0,fearture_time:
1752068072,feature_id:136
*May 31 17:53:44.095: //136/D136EACF803C/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, P
Called Number=222088(TON=Unknown, NPI=ISDN))
*May 31 17:53:44.095: //136/D136EACF803C/CCAPI/cc_process_call_setup_ind:
Event=0x686F6B18
*May 31 17:53:44.095: //136/D136EACF803C/CCAPI/ccCallSetContext:
Context=0x68C05D4C
>>>>CCAPI handed cid 136 with tag 3 to app "_ManagedAppProcess_Default"
*May 31 17:53:44.095: //136/D136EACF803C/CCAPI/ccCallProceeding:
*May 31 17:53:44.099: //136/D136EACF803C/CCAPI/ccCallDisconnect:
use=0)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*May 31 17:53:44.099: //136/D136EACF803C/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*May 31 17:53:44.279: //136/D136EACF803C/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x68742DF8, Tag=0x0, Call Id=136,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*May 31 17:53:44.279: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 31 17:53:44.279: :cc_free_feature_vsa freeing 686E6FE0
*May 31 17:53:44.279: vsacount in free is 0
The cause code is
The debug output shows that the number called is not been translated hence the VG does not have a dial-peer to route the call to CCM. So its not even CCM, its the gateway....
paolo bevilacqua Sun, 05/31/2009 - 16:05
  • Hall of Fame,
    Founding Member
I did not go trough the debug.
The initial q.931 debusg shows an outgoing call, for which the outgoing pots DP is OK.
So, the OP should clarify if he has problems for incoming, outgoing or both calls.
And should then produce the combined output of debug q931 and ccapi, to correlate events.
paolo bevilacqua Sun, 05/31/2009 - 16:01
  • Hall of Fame,
    Founding Member
In my experience, 00 (or 011 in NA) followed by contry code and number, plan/type unknown, is always accepted for international calls.
csshenoy80 Mon, 06/01/2009 - 11:19
I found out the issue, it was a route pattern issue as well as the dial-peer config. Made changes on Route pattern to have the discard digits - Predot and on dial-peer pots, made the destination pattern as .T instead of 9T. This solved the outgoing international call issue.
With regard to the Incoming DID call, I created a new dial-peer voip for the path from voice gateway to call manager for the pattern 2..., its working fine now with the same old translation pattern.
Thank you guys for all the help.
