backup line
May 31st, 2009
Hi friends,
I installed cisco call manger 6.1 with PRI line.
i configure every thing working well and good.i need one backup for pri line so i purchased 4 analog lines .
my question is how i need to configure the 4 analog line as a backup line for pri ,if pri goes off we need to use these analog line.
help me regarding this matter.
thanks
Paolo Bevilacqua Sun, 05/31/2009 - 06:53
  • Hall of Fame,
    Founding Member
Are you using h.323 or mgcp ?
Paolo Bevilacqua Mon, 06/01/2009 - 06:12
  • Hall of Fame,
    Founding Member
I don' think automatic backup can be done with mgcp. Others can give better advice.
Jaime Valencia Mon, 06/01/2009 - 06:16
  • Cisco Employee,
  • Hall of Fame,
    2011
Configure Route Groups and Route Lists with the PRI in 1st place and then analog ports
java
if this helps, please rate
zeuscyril Mon, 06/01/2009 - 21:24
sorry,
i am not able to get your idea, can u please explain brief in the same..
