NAC : CAM control over switch using SNMP
May 31st, 2009
I have CAM , CAS in Central, OOB,Virtual,Layer2 lab
I can see on CAM the access switch ports status which means that SNMP works but when a user is logged on the access switch , the user vlan is not inforced to be changed to Auth vlan
and he remains in the trusted vlan which is already configured on the acces switch
I can change in configuration on the switch through CAM but the CAM itself cant change Vlan
thanks to advise me what part i am missing
Overall Rating: 5 (2 ratings)
ramkumar-b Tue, 06/02/2009 - 00:26
Please check the following items
a. configuring User Pages
b. configure VLAN Mapping
c. Configure Managed Subnets
d. Configure VLAN settings under Port Profiles
halim.abouzeid Fri, 06/12/2009 - 07:21
in the CAM, when you see the access switch ports status, click on the magnifying glass icon next to a port which is up and see if it's detecting the MAC address of the device which is connected to that port. If it is not it means that SNMP mac-notification is not configured properly. If CAM doesn't detect the MAC address of the device, it wont change the switchport vlan...
