Auto Registration CUCM 6
May 31st, 2009
I have a CUCM version 6, and I have problem with the auto registration of the phones. The phone are not registered in the CUCM. I check this parameters:
Cisco Unified CM Configuration:
Auto-REgistration Information:
Starting Directory Number: 5000
Endind Directory Number: 5100
Partition : None
Uncheck the option "Auto - Registration Dissabled on this Cisco Unified Communication -Manager"
Cisco Unified Communications Manager GRoup Information:
Check the option: Auto-registration Cisco Unified Comunication Manager Cisco.
I need set other parameters to work the auto register option in my phones or restart any service??
Overall Rating: 2 (1 ratings)
Jaime Valencia Sun, 05/31/2009 - 20:02
Where are the phones pointing to for the TFTP?
If you set them to look into that server where auto-registration is enabled does it work?
if this helps, please rate
ricardorojas123 Mon, 06/01/2009 - 05:13
Yes with DHCP configuration or IP Static Configuration the phone are registered. But this message is showed: "Registration Rejected : Error DBConfig" (The phone is not auto registered).
